I see no mention of a card slot on the Hub. Does it work with a USB card-reader, so a camera doesn’t need to be connected with USB, to upload files from a memory card? Any recommendations for a good but simple multi-format card-reader?
There is no “card slot” on the WD TV LiveHub.
I have tested it with a usb SD card reader (SDHC 8GB) & it reads pictures just fine.
Make sure you have a backup of all your pictures before you try to read them with the hub.
Click HERE for a list of compatible cameras for the Hub.
