Hello everyone,
I had reset my MyBookLive 2TB using the button on the back of the device. Since then I have no connection. Symptoms are as follows:
- Device powers up and you can hear the HD moving
- Green LED blinks, but does not turn solid.
- Device is not reconized by any HUB or even a direct cross-cable using Windows or MAC OS.
- Network LED is yellow and the green one blinks about once a second.
No connection at all. Does anyone have any suggestions here?
I had opened a ticket with WD on August 26th (two weeks ago), where they stated that it should take one day to reply. Is it normal that it takes so long to get a reply??
Loosing faith in WD…
Jeff
