If you power off HUB completely, restore points of watched videos are “forgotten”. They are present just if HUB is on standby.
I own also Xtreamer, and there are restore points saved in flash memory, so it doesn’t matter if you disconnect it from mains - they are always there. I suggest you do same for HUB.
Has someone come across a solution to this Problem? Now i have to choose between a HDD that runs 24/7 or it does not autoresume my files. I think i will return the product if there is no solution.
I don’t think you read the thread, did you? As I indicated, I have not recently come across an issue where resume data is tossed after a shutdown… and I’ve been rebooting my box several times a day over the last week.
