I have an Admin folder too. I will let you know if it works for me too. It somehow makes sense. Now on to next topic of VPN, hopefully this won’t be too hard. :robothappy:
You da man!
- So I went to “SHARES” I clicked on the folder named “Admin” I renamed it to “Administrator” It wouldn’t work right away as I received a page time out. I verified that the folder was renamed. You may still have the old folder showing temporarly.
- Under Settings>Remote Access>Configure I disabled “Remote Access”
- I enabled “Remote Access” then restarted the MLB under Settings>Utilities>Shutdown/Reboot
- I clicked “rebuild the server” under Settings>Remote Access>Advanced
All the steps above might not be necessary but I decided to do them all before I tested it. Just remember that it is ok to have a user named “Admin” but not a folder.
Finaly I can use MBL to it’s full potential!
Thanks a ton!
