My WD TV Live shows my mpg’s with no problems at all. When I use handbrake to convert them to mp4 or M4v they work fine in VLC or on my MVIX Ultio Pro. But the WD TV Live always has audio sync problems. Is there something in the settings of handbrake I could change that would cure this problem?
What audio format are you trying to use in Handbrake?
I’ve seen issues when using M4V/MP4 + AAC.
If you don’t specifically need M4V/MP4, just use the High Profile Preset and choose MKV as the output file type, and “PASSTHROUGH” audio.
Thank you so much for this.
My handbrake was popping up two lines of audio. I had to remove one.
