Hi guys,
I’m running into a problem with my WD live. It won’t play audio from certain movies I add, I added 10 movies yesterday, it will play the audio for some of them, but other movies just don’t have audio.
The movies I added have a mixture of AC3 and DTS, but I have multiple movies with AC3 & DTS which all play fine.
When I test the files on my computer they all have sound and I have the latest firmware installed.
Anyone got an idea where the problem could be?
Post the text output of MediaInfo for a file that doesn’t work.
Here you go
* just to let you know, I pass the movies through mkvmerge first to mux the subtitles. But I do this with all my movies so I don’t think this is the problem.
General
Complete name : /Users/my name/Movies/Godzilla.mkv
Format : Matroska
File size : 6.55 GiB
Duration : 2h 18mn
Overall bit rate : 6 765 Kbps
Encoded date : UTC 2010-07-08 18:33:15
Writing application : mkvmerge v4.0.0 (‘The Stars were mine’) built on Jun 21 2010 15:47:50
Writing library : libebml v1.0.0 + libmatroska v1.0.0
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Muxing mode : Container profile=Unknown@4.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 18mn
Bit rate : 5 257 Kbps
Width : 1 280 pixels
Height : 536 pixels
Display aspect ratio : 2.35:1
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.320
Stream size : 4.96 GiB (76%)
Writing library : x264 core 78 r1310 ec46ace
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=5257 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Audio
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Duration : 2h 18mn
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Stream size : 1.46 GiB (22%)
Title : DTS 1509 Kbps
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
The new mkvmerge will have this problem with audio – use an older version of it and you should be fine (or uncheck the compressed audio header in the options when you mux).
(See http://community.wdc.com/t5/General-Discussions/Problem-with-WD-TV-live-and-mkv-files-that-have-been-muxed-with/td-p/32142 )
As far as I can see the OP is using the old MKVmerge.
June 21st is the old version? Wow, I guess the new version came out *very* quickly after that (like, um, a week or so?)
- 03 Jul 2010: Released v4.1.1.
- 01 Jul 2010: Released v4.1.0.
- 05 Jun 2010: Released v4.0.0.
So, the header compression started July 1. :)
And I’m still using the February 12th version – works fine for me .
