Thanks for the reply. I ran MediaInfo and this is the info it reported.
I dont want to shoot the messenger, but I was trying to make a point that this is a brand new camera, and presumably the latest software from Canon. It should be supported by WD.
General
Complete name : C:\Users\username\Videos\2010-03-24 Alex Dancing\MVI_0008.MOV
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt
File size : 33.5 MiB
Duration : 11s 733ms
Overall bit rate : 23.9 Mbps
Encoded date : UTC 2010-03-24 20:11:53
Tagged date : UTC 2010-03-24 20:11:53
Video
Format : AVC
Format profile : Baseline@L4.1
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate mode : Variable
Bit rate : 23.2 Mbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 30.000 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.839
Stream size : 32.5 MiB (97%)
Language : English
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : sowt
Bit rate mode : Constant
Bit rate : 705.6 Kbps
Channel(s) : 1 channel
Sampling rate : 44.1 KHz
Resolution : 16 bits
Stream size : 1 011 KiB (3%)
Language : English
General
Complete name : C:\Users\username\Videos\2010-03-24 Alex Dancing\MVI_0008.THM
Format : JPEG
File size : 10.6 KiB
Format : JPEG
Width : 160 pixels
Height : 120 pixels
Resolution : 8 bits
General
Complete name : C:\Users\username\Videos\2010-03-24 Alex Dancing\MVI_0036.MOV
Format : MPEG-4
Codec ID : qt
File size : 222 MiB
Duration : 1mn 17s
Encoded date : UTC 2010-03-24 22:02:39
Tagged date : UTC 2010-03-24 22:02:39
Video
Format : AVC
Codec ID : avc1
Duration : 1mn 17s
Height : 720 pixels
Resolution : 8 bits
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.840
Stream size : 215 MiB (97%)
Language : English
Audio
Format : PCM
Codec ID : sowt
Duration : 1mn 17s
Stream size : 6.54 MiB (3%)
Language : English
General
Complete name : C:\Users\username\Videos\2010-03-24 Alex Dancing\MVI_0036.THM
Format : JPEG
File size : 9.99 KiB
Format : JPEG
Width : 160 pixels
Height : 120 pixels
Resolution : 8 bits
