I upgrade my firmware of 3 to V4 and i dont see my information. I back again to 3 but when i try to start Transmission-daemon failed
-bash-4.2# aptitude install transmission-daemon
The following NEW packages will be installed:
transmission-daemon
0 packages upgraded, 1 newly installed, 0 to remove and 159 not upgraded.
Need to get 0 B/186 kB of archives. After unpacking 366 kB will be used.
W: Ignoring Provides line with DepCompareOp for package libapt-inst
W: Ignoring Provides line with DepCompareOp for package libapt-pkg
W: Ignoring Provides line with DepCompareOp for package libespeak-dev
W: Ignoring Provides line with DepCompareOp for package libespeak1
W: Ignoring Provides line with DepCompareOp for package libgpgme11-dev
W: Ignoring Provides line with DepCompareOp for package kodi-api-guilib
W: Ignoring Provides line with DepCompareOp for package kodi-api-pvr
W: Ignoring Provides line with DepCompareOp for package libparse-cpan-meta-perl
W: Ignoring Provides line with DepCompareOp for package libjpeg62
W: Ignoring Provides line with DepCompareOp for package lsb
W: Ignoring Provides line with DepCompareOp for package lsb-core
W: Ignoring Provides line with DepCompareOp for package php-psr-http-message-implementation
W: Ignoring Provides line with DepCompareOp for package php-psr-log-implementation
W: Ignoring Provides line with DepCompareOp for package php-seclib
W: Ignoring Provides line with DepCompareOp for package php-sabre-http
W: Ignoring Provides line with DepCompareOp for package php-math-biginteger
W: Ignoring Provides line with DepCompareOp for package pkg-config
W: Ignoring Provides line with DepCompareOp for package pypy-cffi
W: Ignoring Provides line with DepCompareOp for package pypy-cffi-backend-api-max
W: Ignoring Provides line with DepCompareOp for package pypy-cffi-backend-api-min
W: Ignoring Provides line with DepCompareOp for package python-cffi-backend-api-max
W: Ignoring Provides line with DepCompareOp for package python-cffi-backend-api-min
W: Ignoring Provides line with DepCompareOp for package python3-cffi-backend-api-max
W: Ignoring Provides line with DepCompareOp for package python3-cffi-backend-api-min
W: Ignoring Provides line with DepCompareOp for package sagenb-export
W: You may want to update the package lists to correct these missing files
Unescaped left brace in regex is deprecated, passed through in regex; marked by <-- HERE in m/^(.?)(\)?${ <-- HERE ([^{}]+)}(.)$/ at /usr/share/perl5/Debconf/Question.pm line 72.
Unescaped left brace in regex is deprecated, passed through in regex; marked by <-- HERE in m/${ <-- HERE ([^}]+)}/ at /usr/share/perl5/Debconf/Config.pm line 30.
Selecting previously unselected package transmission-daemon.
(Reading database … 14094 files and directories currently installed.)
Preparing to unpack …/transmission-daemon_2.92-2_armhf.deb …
Unpacking transmission-daemon (2.92-2) …
Processing triggers for man-db (2.7.0.2-5) …
Setting up transmission-daemon (2.92-2) …
insserv: warning: script ‘K01commgrd’ missing LSB tags and overrides
insserv: warning: script ‘commgrd’ missing LSB tags and overrides
insserv: script atop: service blabla already provided!
insserv: script ramlog.uninst: service ramlog already provided!
invoke-rc.d: -----------------------------------------------------
invoke-rc.d: WARNING: ‘invoke-rc.d transmission-daemon start’ called
invoke-rc.d: during shutdown sequence.
invoke-rc.d: enabling safe mode: initscript policy layer disabled
[…] Starting bittorrent daemon: transmission-daemon/usr/bin/transmission-daemon: error while loading shared libraries: libsystemd.so.0: ELF load command alignment not page-aligned
failed!
invoke-rc.d: initscript transmission-daemon, action “start” failed.
dpkg: error processing package transmission-daemon (–configure):
subprocess installed post-installation script returned error exit status 127
Errors were encountered while processing:
transmission-daemon
E: Sub-process /usr/bin/dpkg returned an error code (1)
A package failed to install. Trying to recover:
failed!
transmission-daemon
