After upgrdae of ex2 ultra firmware 5 and WD smartware issues
HI
Took teh firmware upgrade for yje Ex2 ultra 5.09.115
I have been using WD smaartware backup software of years and now after the upgrade
it says No writable partition found and next to teh drive it has a red cross
I can access all teh documnets and teh partitions
Per WD, Smartware is not supported under OS5. See the following Knowledgebase article that details the differences between OS3 and OS5.
My Cloud OS 5: Feature Differences Between My Cloud OS 3 and My Cloud OS 5
With Smartware no longer supported when one moves to OS5, one may look into using any number of free and paid third party backup programs that support backing a computer to a local network NAS device like the My Cloud devices.
Because you are using an EX2 Ultra you may want to see, and search through, the OS5 My Cloud EX Series subforum where the EX2 Ultra OS5 issues are generally being discussed.
My Cloud EX Series
