Fully understand your reasoning for not having Games and Mobile Access within you original theme menu, thats why I (and no doubt others) appreciate your efforts even more by acknowledging other peoples requests.
Personally i don’t use games or mobile access either but was happy with running on FW 2.07
Thanks again joey and hope the weather gets better soon for yer!!
Yes, this theme works on the gen3 WDTV live Hub, but only on Firmware version 2.04 NOT the current firmware version 3.00. Please read Page 1 for further detailed information.
This theme works on the lower cost SMP. That is what I have. There are a couple minor issues that that I think the creator is working to resolve for the latest firmware of the HUB (as the issues may be the same on the SMP latest firmware).
I experiences movie sheets not being done correctly even when using the template for Thumbgen that was provided (and I think others with the HUB on latest firmware found that too). And I found the homepage/main menu to not be in the correct order (i.e. when I have the current selection on FILES and to the right it says SETUP … I then hit the right arrow button on the remote but I don’t go to SETUP, I go to MUSIC). So the sequencing was wrong for the SMP (or latest firmware … not sure which).
Once the author releases new update for HUB, I expect it will load on the SMP (like most of the other themes).
Few Storms and Blackouts today… didnt get as much done as i hoped.
But i did finish the Home Screen and Setup Screen for FW 2.07.17.
(Games and Mobile Access are now displayed… two things i ironically never use, or would want to.)
Couple of Digital Camera TV pics of todays ‘session’
As well as changing and cleaning up the code and graphics, making minor alterations. (none of this affects the Moviesheets. Im not touching the Moviesheets.)
Played witht he Mobile access with current theme on 2.07 and now I see where the flaw is and why you need ot make that adjustment. “Mobile Access” comes up instead of “ABOUT”. And “About” is a hidden menu.
Are you also going to fix that Settings image [Right screenshot] as the menu bar image is @.04 style in the image and on the TV in the background.
I wasn’t implying you had to support the Live Streaming. I simply meant that since both the Hub and Live Streaming have very similar code bases and the latest FW version for each seems to have the same features/limitations (as far as themeing goes) if your theme worked on the Hub than we Live owners could have the same on our end with only minimal glitches.
Is 3.0 “broken” due to the whole PNG-not-supported thing? Was this a deliberate change in the FW on WD’s part?
