Is there a quick way to ammend information inside the XML file? I have 4 files in my structure:
-Movie.avi
-Movie.avi.tgmd
-Movie.xml
The Good News is … because you have the “.tgmd” file for your Movies you can Quickly Re-Process your Movies without having to Go Online.
Sure, it will Re-Process the Moviesheets as well as the XML’s… to speed things up i would go into Option and change PNG back to JPG and Set the Quality to Maximum. (Quicker to Process a JPG than PNG)
Once finished… Put the Setting back to PNG, Delete the Moviesheets and Copy and Replace the OLD Xml’s with the Newly Created Ones.
Hi First of all thanks for all your great work and keep it up. I seem to be having a problem with the main menu. The titles seem to be in the wrong order when I press left or right it’ll jump 3 or so options, for example if I’m on video and press right it’ll go to music instead of online. Do you know why this is? I’m using firmware 2.04.13 if that helps.
You will find an old Discontinued Version for FW 2.04.13 on that page, But this not include Revised XML & Graphics Changes that are in Æonish Hub FR Revision 2 and the Æonish Hub Media Flag Edition modification.
However it does have the Home Screen XML & Graphics that are Firmware 2.04.13 Compatible.
I really like this theme! I know the WD TV Streaming Media Player (SMP) is not officially supported by the author, but I’m wondering if anyone out there has gotten this theme running on it? I tried installing it and the movie info screen works fine but the movie info doesn’t show in the gallery view and the movie thumbnail looks bad. Below is a screenshot.
This is what happened on latest Hub Firmware as well. The only thing i experimented before rolling back to 2.07.17 was to Lower the Resolution of the Jpeg Moviesheet which requires resizing the Thumbgen template… But after lowering the Res, the backdrop quality was not satisfactory.
Man i just love your theme, but since i’m using the latest firmware, i dont get to fully apreciate it.
Can you help me pointing which xml files do i need to maintain to get the home appearence and full setup from your theme? I understand that the files that i don`t use will be replaced by mocha default theme automaticaly, right?
To Put the issue to rest … all problems are Hardware and Firmware Specific.
hmmmm when i compare the demo xml files and mine from thumbgen i see some difference … this does not affect how the Thumbnails or Moviesheet is Displayed.
i also get no thumbnail/cover or backdrop … PNGs renamed to JPG DO NOT WORK ANYMORE in latest Firmwares.
Media Flags Dont Show ? … “scale” command not working properly in Firmware."
100% Fine and Working in Firmware 2.07.17 for the WDTV Live Hub
Coverbox (Thumbnail) hard to read and Blurry … again “scale” command not working properly in Firmware.
Reducing Image Resolution of Sheet (Converted back to JPG, because PNG Doesn’t Work anymore) does help…
But compromises the entire Picture Quality.
Same problem here. so it can only be solved with an older FW version?
For 100% Working Properly and Displaying as Intended and Designed …
Use Firmware 2.07.17 for the WDTV Live Hub only … not designed for SMP (Which is a Different Device)
