Anybody help me here??
I am a little confused about the Advance Format drive, specificlly it is WD15EARS.
It came with the Advance Format technology like the document said. But i have this question. For now I am using Window XP to use the drive the first time. I have a clean install as a secondary drive so i jumpered 7-8 pins like WD said, then format it as 1 partition for data storage (video, picture, music, document etc…). Later on, i will upgrade it to Windows 7. Do I need to do anything with the pin or something or I just need to plug the HD in and run it as usual? Of course when I upgrade, there will be many of my data in drive. They are my life so I dont want to risk with them.
Thanks ahead for any help.
