Acronis help
I just cloned my C drive to my new 500GB Caviar Blue PATA Internal Drive, and everything went just fine.My problem is that I assumed this would be my new  D drive. This was not the case, so each drive see’s itself as the C drive and other drives are labelled as D.
I wanted a second drive fully operational as a D drive, how do I change my new drive as D only.
Please note the Computer Management Tool cannot change a C drive and depending what drive you are in the tool allready see’s the new drive as D.
You’ll probably have better luck on the Acronis forum http://forum.acronis.com/  They have a lot of helpful stuff posted there.
Joe
