Hello!
Im from Chile, i have a problem with my Wd sentinel DX4000, my configuration is 4x2tb and the WD recognize only 3 bays, i make a recovery, and change the disks (the disks is not the problem).
The log of the re-creation :
******************** Driver Version Check DISABLED ********************
;Port,Model,SerialNumber,FirmwareVersion,Array,Status,Size,Free,Type
2,“WDC WD2009FYPX-09AAM”,“WD-WCC1H0866095”,“01.01D0”,0,“Normal”,3907029168,4367,“ArrayMember”
3,“WDC WD2009FYPX-09AAM”,“WD-WCC1H0725900”,“01.01D0”,0,“Normal”,3907029168,4367,“ArrayMember”
4,“WDC WD2009FYPX-09AAM”,“WD-WCC1H0841513”,“01.01D0”,0,“Normal”,3907029168,4367,“ArrayMember”
2009.01.01 05:07:49 - INFO - RaidCfg64 detected 3 drives
2009.01.01 05:07:49 - INFO - RaidCfg64 drive WD-WCC1H0725900: port=3
2009.01.01 05:07:49 - INFO - RaidCfg64 drive WD-WCC1H0841513: port=4
2009.01.01 05:07:49 - INFO - RaidCfg64 drive WD-WCC1H0866095: port=2
2009.01.01 05:07:49 - INFO - Matched drive 1 serial WD-WCC1H0725900 model WDC WD2009FYPX-09AAMB0 with white list entry Enterprise Storage 2 TB
2009.01.01 05:07:49 - INFO - Matched drive 2 serial WD-WCC1H0841513 model WDC WD2009FYPX-09AAMB0 with white list entry Enterprise Storage 2 TB
2009.01.01 05:07:49 - INFO - Matched drive 0 serial WD-WCC1H0866095 model WDC WD2009FYPX-09AAMB0 with white list entry Enterprise Storage 2 TB
2009.01.01 05:07:49 - INFO - Checking RAID status (1): Volume Good
2009.01.01 05:07:51 - INFO - Detected drive 0 serial=WD-WCC1H0866095 model=WDC WD2009FYPX-09AAMB0 SATA=2 led=0
2009.01.01 05:07:51 - INFO - Security: SUPPORTED
2009.01.01 05:07:51 - INFO - Enabled: 0
2009.01.01 05:07:51 - INFO - Locked: 0
2009.01.01 05:07:51 - INFO - Frozen: 0
2009.01.01 05:07:51 - INFO - Master Password Id supported: 1
2009.01.01 05:07:51 - INFO - Master Password Id: 0xFFFE
2009.01.01 05:07:51 - INFO - Master Password Capability: None
2009.01.01 05:07:51 - INFO - Unlock Attempt Counter Exceeded: 0
2009.01.01 05:07:51 - INFO - Enhanced Erase: 1
2009.01.01 05:07:51 - INFO - Erase Time: Normal (raw 255; 50400 sec)
2009.01.01 05:07:51 - INFO - Erase Time: Enhanced (raw 255; 50400 sec)
2009.01.01 05:07:51 - INFO - Detected drive 1 serial=WD-WCC1H0725900 model=WDC WD2009FYPX-09AAMB0 SATA=3 led=1
2009.01.01 05:07:51 - INFO - Detected drive 2 serial=WD-WCC1H0841513 model=WDC WD2009FYPX-09AAMB0 SATA=4 led=2
2009.01.01 05:07:51 - INFO - C:\wdrecovery\raidcfg64.exe /i
2009.01.01 05:07:51 - INFO - raidcfg64.exe /i Output:
Version Tables:
Driver Version: 10.8.0.1003
OROM Version: 10.5.5.1050
App Version: 10.5.6.1002
Physical Disks Controlled by RAID S/W
Disk 01 / 03
Disk: WDC WD2009FYPX-09AAM SerialNo:WD-WCC1H0866095
Description:09FYPX-09AAM Summary:Array Member
Rev:01.01D0 Summary:Array Member
FreeBlks:0x110F TotalBlks:0xE8E088B0
BusId:0x00000002 TargetId:0x00000000 LUN:0x00000000 Array:0x00
Partitions:02 CheckBox:0x00000000 CfgStatus:(00) Ok
Action:00 SMARTEvt:0x00000001 WriteCache:ON
State:(0x0000053A)
CONFIGURED_DISK
USABLE_DISK
DETECTED_DISK
CLAIMED_DISK
CONFIG_ON_DISK
DISK_SMART_EVENT_SUPPORTED
Disk 02 / 03
Disk: WDC WD2009FYPX-09AAM SerialNo:WD-WCC1H0725900
BusId:0x00000003 TargetId:0x00000000 LUN:0x00000000 Array:0x00
State:(0x0000053A)
CONFIGURED_DISK
USABLE_DISK
DETECTED_DISK
CLAIMED_DISK
CONFIG_ON_DISK
Disk 03 / 03
Disk: WDC WD2009FYPX-09AAM SerialNo:WD-WCC1H0841513
BusId:0x00000004 TargetId:0x00000000 LUN:0x00000000 Array:0x00
State:(0x0000053A)
CONFIGURED_DISK
USABLE_DISK
DETECTED_DISK
CLAIMED_DISK
CONFIG_ON_DISK
Total Physical Disks = 3
RAID Volumes
Volume 01 / 01
SerialNo:Volume0 Summary:Normal
RaidLevel: 5 MemberDisks:03 Domains/Mirrors:01 TargetId:0x01
SizeInMB:3815453 BytesPerBlock:0x00000200 StripSize: 64KB
Action:00 Array:00 MapState:00 MigrState:00 MigrType:00 CfgStatus:0x00000000
Total Volumes = 1
RAID Arrays
Array 01 / 01
NumDisks:03 RAIDDevs:01 TotalMB:5723186 FreeMB:6
State:00 CheckBox:0x00000000
Total Arrays = 1
2009.01.01 05:07:51 - INFO - C:\wdrecovery\raidcfg64.exe /std
2009.01.01 05:07:51 - INFO - raidcfg64.exe /std Output:
2009.01.01 05:07:51 - INFO - RaidCfg64 detected 3 drives
2009.01.01 05:07:51 - INFO - RaidCfg64 drive WD-WCC1H0725900: port=3
2009.01.01 05:07:51 - INFO - RaidCfg64 drive WD-WCC1H0841513: port=4
2009.01.01 05:07:51 - INFO - RaidCfg64 drive WD-WCC1H0866095: port=2
2009.01.01 05:07:51 - INFO - Matched drive 1 serial WD-WCC1H0725900 model WDC WD2009FYPX-09AAMB0 with white list entry Enterprise Storage 2 TB
2009.01.01 05:07:51 - INFO - Matched drive 2 serial WD-WCC1H0841513 model WDC WD2009FYPX-09AAMB0 with white list entry Enterprise Storage 2 TB
2009.01.01 05:07:51 - INFO - Matched drive 0 serial WD-WCC1H0866095 model WDC WD2009FYPX-09AAMB0 with white list entry Enterprise Storage 2 TB
2009.01.01 05:07:51 - INFO - Checking RAID status (2): Volume Good
2009.01.01 05:07:52 - INFO - Enabling write-cache
2009.01.01 05:07:52 - INFO - Attempt to find ATA disk Volume0
2009.01.01 05:07:52 - INFO - Obtained 20 bytes of VPD SERIAL DATA out of 24 transferred
2009.01.01 05:07:52 - DEBUG - \.\PhysicalDrive0 serial=‘Volume0’
2009.01.01 05:07:52 - INFO - Volume Volume0 write-cache is on
2009.01.01 05:07:52 - INFO - Successfully set write-cache on volume Volume0
2009.01.01 05:07:52 - INFO - Verify volume Volume0 write-cache is on
2009.01.01 05:07:54 - INFO - =========== Recovery app END (0) ===========
Thanks for the solutions!
