3TB Enclosure help
Hi guys,
can anyone recommend a single bay external enclosure for a WD 3TB green drive?
newegg has a couple that state they can handle 3TB but most of the reviews are terrible.
is anyone here using an external case that they recommend?
thanks very much
As long as the enclosure supports the drives capacity there will be no problem
a bad enclosure is a bad enclosure so pay attention to those reviews and try to get a decent one
