i have a 20tb book duo.
2 x 10tb red drives set up as raid 1 system (mirrored)
the case has failed…no power
have contacted WD and was given useless help
i need access to the data that is CRITICAL
i believe the drives or ok but can not test as case has no power.
wd suggestion was buy new wd hdd…can not get a new case on its own. ( if i could i would)
so what other docks /enclosure can i use to get the data?
can some give me an honest answer, i really need to get my data. that’s why i got that hdd in the first place so that i had a back for my data. if the case/enclosure failed i could put into other docks or get replacement case…it sounds that does not work with WD , that’s something they dont mention when selling there products
again what other docks /enclosure can i use to get the data?
HELP
