1TB WD Elements small portable Drive
The above drive has gone into uninitiated status as shown in Computer management- disk management. I tried to initiate the drive but it come up with “X-  the media is Write Protected”   do’s anyone know how to remove Write Protect
so I can initiate the Drive ? on either Toshiba laptop windows 7 or a HP  pc running Vista
Thanking you in anticipation   Regards
vikingdw1,
I would suggest a deep disk erase by means of a low-level format using Western Digital Data Lifeguard Diagnostics for Microsoft Windows, as detailed in the following link:
http://wdc.custhelp.com/app/answers/detail/a_id/1211/
