Hi
I just set up my first Duo 2 x 3 TB but figured it will not be too long before my data will extend 3 TB. So my idea is, instead of using 1 Duo with RAID for 3 TB, I use the full 6TB of storage and then connect another DUO to it via USB.
So I could save 6 TB on the first DUO and back them up to the second DUO.
questions:
would this setup work?
could I synchronise those 2 drives (mirroring DUO 1) automatically? (I will backup remotely via personalCloud) and, if yes, how would this be done best? (on Windows)
would appreciate your help.
Phill
