1.04.22_V gave me HICKUPS & SPEED problems on everything
Just upgraded over the internet from 4.17 to 4.22
All my files streaming from shared folders are suddenly full of hickups and freeze-frame problems.
It does not matter which i choose i.e. AVI - MPEG - VOB - MKV , you name it, all are suffering the same problem.
Is there a fix for it already? (LOOKS LIKE IT WAS NOT TESTED PROPERLY) what is wrong?
and where is a simple remote desktop feature.
If you can stream 1080P full screen, it sure can stream a simple desktop-copy  screen.
Have you tried a side button reset?
No, but i will try tomorrow… thnx for the suggestion (hope it will help me on this problem)
