I have been using my WD MyBook wireless external HD for a long time. Last week however it dissapeared from “Computer” and only C: and D: drive is visible.
Right clicking the Windows Explorer on hte Task Bar I can see it and open it, however my Norton Backup program do not find it and I can’t back up my PC.
The My Book Live is not a wireless drive. If its not seen on the computer make sure the drive is properly connected to the router. You can also try a reset and/or power cycle.
