WDTV system freezing when ejecting hard drives
Hope someone can help.
I have the latest firmware installed on the WDTV Live and when I plug a hard drive in and use it even for about 10 minutes, when it comes to ejecting the hard drive the player just freezes with the circle loading bars going round. It does this for a long time and I end up having to to unplug the hard drive whilst it is still powered which I do dnot want to do, then I have to unlug the media player from the power to turn it off.
This happens on all of my hard drives, 3 of which are Western Digital 3.5 Desktop drives, and 1 is a Western Digital Elements portable drive
On a side note, if I put the hard drive in, and then straight away eject it, it is fine and has no issues, but if I view ANY type of file or keep it in for more than 5 minutes or so, it will not eject
Thanks in advance!
Make sure that you stop the file that you are playing before you hit the eject button.
Also you may try resetting the media player and test that again.
