For testing purposes, I would recommend a manual firmware update/rollback by means of a USB disk drive in order to address the possibility of a firmware behavior error. If this procedure is unable to address the situation at hand, the unfortunately you may need to consider a free replacement under warranty.
Instructions for a firmware update/rollback are available in the following links:
