So i have a 1tb my passport ultra and when I connect it to my usb hub, everything appears to be normal, but when i try to copy files it stops about halfway and windows 7 says its estimating file size. I left it for about 10 minutes and nothing happened. When i plug it directly into the computer however, everything works without issue. Is there a reason for this? Is there something wrong with the drive? Should i have it replaced? I just bought it. I have no issue using my old my passport model on the usb hub. also, will connecting it to a powered hub bad? Will it fry the drive.
Thanks in advance.
