I recently replaced my two WDTV Live+ boxes with the new Live SMP. So far I like the new boxes much better, however I just ran into a strange audio sync issue with only one of my MKVs. The strange part is that the audio sync issue is only on the system that has the audio out to my receiver via optical; the other system configuration the receiver gets the audio via HDMI. The other strange part is that the audio sync issue (and it’s about a 200ms lag) is only with one movie (national lampoons christmas vacation). All other movies that I’ve played, play just fine on the same system with no apparent audio lag. Also, I don’t recall having this issue with the previous WDTV Live + that was previously set up the exact same way.
Media info for the file is below, but I have a feeling that there’s something about the file and how the SMP is handling it that’s causing the sync issue.
Any thoughts greatly appreciated.
Thanks!
General | |
Unique ID : | 25298908008332461071899050009659437371 (0x130864778F97247C4AE2CD80CBEBF13B) |
Complete name : | V:\GROWN UPS\HOLIDAY\NATIONAL LAMPOONS CHRISTMAS VACATION.mkv |
Format : | Matroska |
Format version : | Version 2 |
File size : | 12.7 GiB |
Duration : | 1h 37mn |
Overall bit rate : | 18.7 Mbps |
Encoded date : | UTC 2011-11-17 02:05:22 |
Writing application : | MakeMKV v1.6.16 win(x64-release) |
Writing library : | libmakemkv v1.6.16 (1.2.0/1.1.0) win(x64-release) |
Video | |
ID : | 1 |
Format : | VC-1 |
Format profile : | AP@L3 |
Codec ID : | WVC1 |
Codec ID/Hint : | Microsoft |
Bit rate : | 18.1 Mbps |
Width : | 1 920 pixels |
Height : | 1 080 pixels |
Display aspect ratio : | 16:9 |
Frame rate : | 23.976 fps |
Chroma subsampling : | 4:2:0 |
Bit depth : | 8 bits |
Scan type : | Progressive |
Compression mode : | Lossy |
Bits/(Pixel*Frame) : | 0.365 |
Stream size : | 12.3 GiB (97%) |
Language : | English |
Default : | Yes |
Forced : | No |
Audio | |
ID : | 2 |
Format : | AC-3 |
Format/Info : | Audio Coding 3 |
Format profile : | Dolby Digital |
Mode extension : | CM (complete main) |
Codec ID : | A_AC3 |
Bit rate mode : | Constant |
Bit rate : | 192 Kbps |
Channel(s) : | 2 channels |
Channel positions : | Front: L R |
Sampling rate : | 48.0 KHz |
Bit depth : | 16 bits |
Stream size : | 133 MiB (1%) |
Title : | 2/0 |
Default : | Yes |
Forced : | No |
