I’ve had my WD Live plus for a while been the occasional hiccup but that is to be expected since it’s sort of a computer and they like to mess with users.
So turned it on went to press down on the remote to select something and instead of the normal move one spot it does several (4-5) it also does it for any direction up-down left-right. I have a harmony remote programmed for it so tried it also same result thought maybe a button was stuck on the original so removed the batteries tried the harmony same thing. Thought interference so turned off things unplugged stuff in room same. Unplugged the WD plugged it back same.
Any other ideas?
EDIT
Wanted to add using an older firmware since it works fine for me.
