Was working fine last night then we had a trip in the power to the house.
Now when I power on it goes through blue to solid yellow and never further.
Ethernet is blinking.
I can ping it.
I get no reaction when i try pressing the reset button for up to 10 seconds.
I see the login page with ip typed into web browser. Type in wrong pass it tells you - type in correct it clears the textbox but goes nowhere but it does not say incorrect.
Can you reset with no hard disks installed?
Wd quick view sees it.
Shows healthy raid
No temp
Still can not access interface
Can put to sleep via quick view though.
Is there a way to reload firmware without pc? Since i can not get to software interface.
