Hello im new here, I bought my passport 2TB 7 months back suddenly I not able to access the data’s inside, this problem occured because i fixed registry problems in my laptop via cc cleaner while the external hdd was still plugged in, suddenly when i plugged in again it should popup in my computer asI CD DRIVE (G:) WD UNLOCKER, but it just popup there as CD DRIVE. I read alot of forums online most of them wrote about disk management, device manager and command prompt, since my hdd is password protected i cant do anything, even I downloaded data recovery soft shows that no readable partition, please help me, I need al trhe data’s!!
Hi Heman91, have you tried connecting the Passport to another PC?
Hi just a little note Google ccleaner destroyed my computer and you get 139,000 results even if only 1/4 of them is true it is a program to stay away from.
I’ve used Ccleaner for years and never had problems with it. I just updated it today. I’ve used it since Windows 98 up to Windows 7. I didn’t know thee was a Google version.
Joe
Hi there is not a Google version they have enough bad software all on there own hehe. I meant to run a search on Google using the search string “ccleaner destroyed my computer” and see the results. Myself I just delete temp files and clear the ie cache I don’t really need a program to do that.
yes brother, but its still the same please help me bro thanks for ur concern brother
haha yeah im so confused how to fix this
yeap you are right i never knew there was a google version too
do you have any idea what i should do now, I badly need the data’s
Hi Heman91 I have one other question for you did you use the safely remove hardware function before you unplugged the drive. If you do not use that function it’s just a matter of time until you get a Partition Table Corruption rendering all data on that drive unreadable. It may not have been cc cleaner that caused the problem.
If the drive is corrupt then something like TestDisk http://www.cgsecurity.org/wiki/TestDisk might fix it.
joe
bro thanks for ur suggestion i have tried this, doesnt help, it just detects my internal hard drive not the external
bro, u mean that i have to wait…?
