Is there any way that i can get a better transfer speed to our TBL? i get a 5mb/s max its that normal? its there any way to get higher speed?
As long as you provide absolutely no information what so ever, it’s very hard to help you
What router are you using, are your computer(s) able to handle Gbit-speeds, are connecting wirelessly (5 GHz or 2,4?) or are you connected with an ethernet cable, are you using home plugs, how many devices are connected to the network?
