Hello, I have a Mybook for Mac and I am using it on a PC. It has been working wonderfully until I accidently drop it from knee-height.
The symptoms:
-Immediately afterwards I lost power to the hard drive, when i try to plug the power supply in and plug the usb cord to my computer the light won’t show up.
-After 2 minutes, the lights came on and flashes.
-My computer detects a new hard drive now and is installing the hard drive again (It worked perfectly before).
-After installing the hard drive, when I open up My Computer. My laptop can’t see the hard drive.
-I went to disc manager and uninstall the driver and it AUTOMATICALLY reinstalls the driver again.
-Now when I go to disc manager I can see the driver installed and connected and it says its working properly. However I still can’t see it on My Computer.
NOTE: The hardrive still spins when I plug in the power supply and then the sound stops after a minute or two. ( I don’t know whether or not it stops spinning cuz I am not using it, or it doesn’t have enough power to keep on spinning.)
Leon
