Yesterday, after a power outage, my 2 TiB MyBook Live (and my router) stopped working and now (after having fixed the router) it give me a solid red LED (the rear LEDs are both green; one solid and the other blinking; slowly).
I’ve tried to power off and on the MBL, to reset and to direct-link the MBL to the PC (a Mac). Still nothing.
I can’t even ping (nor SSH) the device; the router doesn’t recognize it.
What can I do ?
I don’t have any backup (the MBL itselft was supposed to be) of the 1.1+ TiB of data…
The manual wasn’t useful… it just says “bad things”; not how to fix them.
The unbrick guide seems not very easy and, by the way, I don’t have any other HDD where I can put those files; I used the term “backup” in the (wrong) way in order to say “external [safe ?!] store” (even if I put my own pc backups on it; on different partition).
So, are there any other solution rather than buying (at least) a SATA docking station and do all these stuffs ?
O.T.: As you could imagine, I’m not a native English speaker; I try to do my best in order to be understood.
Those things, yes they are bad, but knowing what it means will give you and idea what the problem is. All except for temperature are related to OS and/or hard drive issues.
In your case, if you are 100% temperature is not an issue, I do not believe there is any other option.
There are two possible scenarios:
Power outage caused the OS to be corrupted. Use unbrick guide to recover files and restore OS
Power outage caused the hard drive failure/malfunction. Use unbrick guide to recover files, if possible at all
If under warranty, contact WD, you might be able to get a replacement. However, chances are WD will not recover your files.
Opening enclosure and removing hard drive as specified in guide, will void your warranty, be aware.
Thanks for all… I’ll try to unbrick and recover by myself.
I’ve asked an estimation to a known data recovery firm partner with WD and they asked me ~600 € (with a 40% “discount”); not very cheap. Especially if I take in account the eventually necessity to buy another NAS.
