Some more tests and the results are confusing. There’s been no disconnect with the CNMemory drive ever. But the Verbatim drive acted weird during my tests:
#1: disconnected after 2 hours of playback
#2: disconnected while doing 10 min skips through Avatar, just before the end credits
#3: played through the whole 3 hours of Avatar
#4: disconnected ~46 mins into the movie and right again after another 6 mins
Given these inconsistencies it’s no wonder WD has a hard time of reproducing this bug.
I had a friend over with her new WD Passport 1 TB who lend it to me for a few days. So I’ve done 3 movie nights in a row and only yesterday the drive disconnected twice in a row (after two nights without any problems) when connected to the back USB. Connected to the front there were no further disconnects.
Same issue here with most current firmware to date, but I have a couple of suggestions regarding what may be the problem. I was experiencing this problem with an mkv shortly after I accidentally hit Eject on MY BOOK rather than the USB key that was plugged unto the front USB. This Eject never worked, and eventually I had to just unplug the device even though the “wait” icon was still spinning on the Eject. After that I started experiencing this problem. Now, however, the movie in question is playing fine.
Maybe one of the following actions I performed actually made a difference. You be the judge…
I plugged the My Book into my PC and I did a checkdisk. This, by the way, didn’t solve the problem after I plugged it back in immediately after. But perhaps it was a necessary step on the road to recovery so I’ll mention it here anyway. Chkdsk did, however, find and address an issue. Who knows…
After I found that “Clear Media Library” from the Setup menu didn’t resolve the issue, I ejected MY BOOK again (this time it ejected fine), and using my PC I manually deleted all .wd_tv folders.
The freezing and disconnecting appeared to be happening at scene changes. I went over how I created the MKV file again (I used MKVTOOLNIX - MKV Merge Gui) and I noticed that the original source contained Chapters. I re-muxed the file, this time excluding the Chapters from the selection.
As I said, the new .mkv appears to be working fine, but perhaps the above actions can either help people who are experiencing the same issue, or give WD a pointer toward the actual cause of the problem so they can fix it in a future firmware release.
Sadly, my previous endeavours were in vain. I fast-forwarded through the .mkv and played chunks of it, and it all seemed well, but when my daughter tried to watch the whole movie later that day it froze again and unmounted the drive.
I then moved the USB connector to the front USB slot and, as many people here have already pointed out, it plays fine through the FRONT USB slot. So the issue seems to affect the back slot only. But, not only is a permanent cable plugged into the front of the WDTVLive unsightly, it also makes it less user friendly. Now I would have to plug a USB key with a new movie into the BACK of the box, before I could move it from there to the WD My Book - and that’s a Pain in the Proverbial, as one would then constantly have to move the WDTVLive box back and forth. I wanted a more permanent solution.
So I tried three more things, and this time the movie has been playing quite happily for over an hour. This is what I did THIS time:
I once again ran a chkdsk against the disk, but this time I went for the full shebang, fixing everything it could possibly find, including sectors etc. It took hours to run, and it didn’t appear to find any issues.
I de-fragmented the WD My Book
Finally, I realised that most people seem to be having issues with USB 3 connections. My WD My Book is a new 4TB drive with a USB 3 connection too. So I was wondering whether this is some incompatibility between the WDTVLive and USB 3. So …
I found a little USB 2 splitter I had, and I plugged it into the WDTVLive’s back port, and I plugged my fancy USB 3 WD My Book into the splitter. Yes, I know, it brings the speed down to USB 2, but that’s plenty fast enough for even 1080p playback, so all I have to say about THAT is [shrug] and “meh”.
Thing is, the movie is now playing beautifully, through the BACK USB connection.
So there you have it. Three more things you may want to try if YOU are having this issue and, WD staff? ANYONE HOME? Does any of this ring any bells with you guys? Just checking…
Are those two mkvs two different encodings of the same source? I, too, have some mkvs encoded at h.264 and 1080p that work just fine and dandy, and others that cause this problem. The only real difference I can see is the size; one is over 4GB in size and it causes the problem, the other is under 4GB in size and it doesn’t.
If you are experiencing this with the same movie, but two different ways of encoding it, I’d love to hear what you’re doing different from one version to the next.
I’m no technician but my guess is that it’s an incompatibility between USB3 and the back port (which differs from the front port somehow). Maybe some of these drives draw too much power when switched on or something.
I am not sure if the problem it´s power. I think there is some hardware incompatibility between USB 3.0 drivers and the USB back port. And WD can´t solve that problem with a firmware update. The questions are: is there incompatibility with all USB 3.0 drivers or only with some models? and the another one is, are there also problems with the USB 2.0 drivers or only with USB 3.0?.
Somebody in WD suggested that I should try an actual USB 2 cable - micro-USB on the WD “My Book” end, and ordinary USB 2 on the WDTV Live end. I’ll try this tonight, and I’ll let you know.
"The issue is already resolved by WD Engineers with new type of firmware.
But its not released yet, need bug fixes and so on.
So will take some time, until its released officially. Be patient "
From where do you have this knowledge? Others havent seem to be able to get the answers you have gotten.
I’m afraid that WD’s suggestion to use a micro USB connection to the USB 3 output of the WD “My Book” didn’t work. The problem is still the same. As the movie is playing the “My Book” is unmounted and the WD TV Live thinks that there no longer is Local Storage connected to it.
