I have a WD Ext. Drive model WD2500B for up to XP OS. Is there a driver update for it that will allow its use with Windows 7?
Unfortunately, there are no firmware updates available for this particular device. However, Microsoft Windows 7 should be able to trigger generic driver support for compatibility, and the device may need to be re-partitioned.
“Trigger” driver support? What does that mean, exactly? Is there a method you can provide by which I can find out if Microsoft can “trigger” driver support?
