The Problem:
The problem is that when you use the WD MyBook Live Web Interface
to view the status of the twonky media server you get something like the following screenshot show
The Cause:
The cause of the problem is usually caused when one follows one of the many guides that exist
to assist one in attempting to upgrade the Twonky Server 5.1.9 that came preinstalled on the WD MyBook Live
to a newer version of Twonky Server, either the user or the guide dont take the existing files into consideration
of which some of them are used by the WD MyBookLive Web Interface for Media Status
For Example:
/usr/local/sbin/getMediaServerPort.sh is looking for /CacheVolume/twonkymedia/twonkymedia-config.html
to determine the port number to connect to the twonky server to get status from the server
If the file /CacheVolume/twonkymedia/twonkymedia-config.html does not exist its game over for status
The Resolution:
The resolution to the problem is relatively easy, which should bring back the status
of the twonky media server back to normal like the following screenshot shows
1. Enable SSH access http://mybooklive/Ui/Ssh
2. Connect using WinSCP, user is “root” password is “welc0me”
3. Open the folder /CacheVolume/twonkymedia
NOTES:
- If the folder twonkymedia does not exist in the folder CacheVolume create it
4.
Click on FILES and then highlight NEW and then click on LINK
5.
Enter “twonkymedia-config.html” in the Link/shortcut: box
Enter “/CacheVolume/twonkymedia/twonky-config.html” in the Point Link/shortcut to: box
NOTES:
If the file “/CacheVolume/twonkymedia/twonky-config.html” does not
exist it is most likely in the folder /var/twonky/TwonkyServer
If it is then use “/var/twonky/TwonkyServer/twonkymedia/twonky-config.html” as the Point Link/shortcut to:
If it does not, your are going to need to figure out where the file is to continue
All Done.
If the Twonky Server is running, and if you reopen a web page to the WD MyBook Live Web Interface
You should now have a working Twonky Media Status page again
If you do not, then there is something else going on, beyond the scope of this guide
Note:
One possibility is the port Twonky Server is running under is not 9000
Another is is the twonky service is actually stopped, even thought the wd gui shows it as enabled
Reccomendations
Dont even bother with the WD MyBook Live Web Interface for Twonky Server Status
I would use the Twonky Server Web Interface directly to do that HTTP://MYBOOKLIVE:9000
