Hi, so let me start by saying for the past year half my setup has consisted of a 3TB external hard drive and a 2TB external hard drive both WD and plugged into the same WDTV SMP though usb2.0. that SMP was then connected to my gigabit network through cat6 cable i ran myself, it in turn fed movies and tv shows to 4 other boxes flawlessly all connected with cat6 cable to my network. i could have 4 boxes going at once no problems ever. all my movies are backed up at 5000kbs so really not that much bandwidth needed.
ok so i purchased a Drobo 5N because i am at the point where if the external harddrive fails id be screwed. so i plug in the drobo set it all up. im starting with (2) 4TB WD red drives.(wd40efrx). set up my Movies share on my drobo and start by transfering 4 movies as a test to see how long it takes. very happy with transfer speeds. so i go to test one of the movies, load up the SMP everything loads up great, have to select new content source. go to windows shares, find the drobo, loads great. i only use large grid thumbnail view. no movie sheets or anything. all my thumbnails are there and looks just like normal. select the movie it loads up right away starts playign looks great. then the movie freezes for about 3 seconds. and then it speeds forward to the point that it would have been at if it did not freeze.
ive done a bunch of research find alot of threads that are year+ old having the same exact problem felt like i was reading the same info 100x over so thought id ask here if anyone knows anything new or has any advice. sometines the video can run for 5 minutes flawless and then freeze. i have tested 2 movies about 15 times each( just the first 10-15 mins) and they freeze at different spots just about every single time. i know the videos are fine because i can play them back on my PC jsut fine from the drobo. also have tested the videos on my old setup and they work perfect.
so i i know it should not be an issuse with wireing or network. but i have read that since the WD SMP’s only have a 10/100 ethernet port in them that it could cause an issuse when recieveing at gigabit speeds. somethign about the packet size when sent over gigabit is larger and the WDTV 10/100 port can not handle it. before i was send video from a SMP with the 10/100 port over a gigabit network to other SMP with 10/100 ports… now im sending straight from gigabit port to 10/100 ports.
i honestly have no clue what is wrong so i dont know how to go abotu tryign to fix it. i am wondering if it can be something as simple as adding a msata ssd to the drobo, dont think data speeds are the problem though.
what i really want to try but dont want to buy one until i get some kind of input first is, if i buy a 10/100 hub and replace my gigabit hub will this in turn make the packet sizes the same across all my SMP’s and drobo. i do not understand how it all works jsut read on an old form someone listed it could be the problem.
i have no problem streaming to my pc which is gigabit port.
any help is greatly appreciated, also any ideas for me to try or anyone with the same problem and how you went about fixing it.
i have a linksys EA4500 router and my gub is linksys as well but dont knwo the model # off top of my head but it was gigabit as well.
