But, WD really dont want to update the firmware? The last firm of this great (sometimes) WD TV LIve will be a fail?
Q1 if I go back to 2.01.86 will auto update online offer 2.02.32 or the newest version ?
Q2 for usb update to work the ver file must be higher than the firmware on the box
so ive edited the ver file to say VERSION=‘4.02.32’ for 2.02.32 would this work okay and rollback with no problems ?
note the rollback version of 2.01.86 has a number of VERSION='4.01.86
thanks
Yes … but if you disable “Detect New Firmware” then it won’t
That’s correct … but not necessary, rollback firmware *.ver file is already edited
Just Follow my guide to rollback to 2.01.86 step by step and it will work
