The audio for the first track on a DVD or Blu-ray on a a network share does not play if it is “dolby digital”. (I have not tried playback from a local drive). The audio for all other tracks (including “dolby digital”) work. Switching back to track 1 again and the audio stops working. All other audio formats are working properly.
Firmware: 2.01.86
What happened: For .ISO files (both BD & DVD) If Audio track 1 is “Dolby Digital” it will not play. All other tracks (including Dolby Digital tracks) will work.
What are you doing: Trying to play an .ISO
Does this happen every time: Yes
What hardware and media were you using: I was using a WD TV Live streaming an .ISO from a Synology 1513+ via SMB share
Did this happen with previous firmware: No
Does power cycling the unit solve this: No
Does resetting the factory defaults solve this: No (it was annoying that I had to do this and reset all my settings)
Have you tried this on other devices: Yes. I set up a XBMC mini-computer to test streaming .ISO files. It worked (but the box is old and slow).
