as the Title discribes, i would like to use a WD5003AZEX in an older external HDD-Case (for max. 500 GB) with SATA 2 Interface and USB 2.0 output, only to store files and folders forever. Do i have to set a jumper in this case or is that only necessary for old motherboards if an OS shall be installed on them?
http://wdc.custhelp.com/app/answers/detail/search/1/a_id/5387#jumper
On the other hand i plan to use a WD1003FZEX in a Docking Station with SATA 2 Interface and USB 2.0 output also to store files and folders forever on it. What about this case?
Personally i think that the normal SATA backwards compatibility should be enough. Am i right?
Just in case someone here would like to tell me that Blue, Green or Red would be enough for my requirements:
I have to tell you that i principly only buy Black because of Quality and Warranty. As i also only burn on Verbatim Gold Archival Grade Single Layers for Lifetime.
Kind Regards
