But I think in your given demo material Æonish Hub Demo Folders for Your Hub/Æonish Hub Music Demo Folder
these files are already created.
With album_playback.xml and view/info everything is perfect.
I just wonder what is missing for rv_list_browse_page.xml and rv_music_browse_page.xml .
QUESTIONS:
1.) Are rv_list_browse_page.xml and rv_music_browse_page.xml using the same “source” jpg and is it because of a too new FW when I still see default pictures (red curtain in background and grey albums) there ?
2.) Do we have to create something more to see the demo like in the screenshots (different folder icons for music icons on the bottom line , the actual in the middle bigger, band-picture in the background - I think it is the rv_music_browse_page.xml of normal AEONISH ) ?
Answer: it’s a Firmware issue Not an XML issue ie. Nothing can be done, unless your a Firmware Engineer / Developer.
You must remember this Theme is Designed for the WDTV Live Hub for Firmware 2.07.17 or lower.
It just wont work properly on other Firmware or Devices (SMP) and there is simply Nothing i can do about it.
I cannot offer anymore assistance or advice as Firmware Related Issues and Device issues, is beyond my control.
I have been trying to use this theme on SMP and it seems to work pretty well, but the only problem that I having is getting the moviesheets to show properly. I create them using Thumbgen and they show up with the them, but the resolution of the pictures in the moviesheet are so bad that it is unusable.
My initial thought was that since the Aeonish template is set to export an image that is small that mabye if I increased the resolution of the template it would display better (being that the bg images and cover art are HD), but that didn’t work. It seems like the theme just zooms in on the pictures even more, making it even worst. I have also tried to use the Aeonish Demo folder and didn’t have great results either…
I have been working on this for the last 3-4 days and am at my wits end. I have read tons of posts, instructions, and tutorials and none of them seem to address this issue.
Just to be clear I have a SMP box with the lates firmware, a 55" 1080p TV, and am connecting to my media via network share (though I have tried with local media also).
It wont work 100% on a SMP or on Live Hub Firmware Above 2.07.17
I cant help, because the problem is Firmware and Device Design.
am the first Time here, I just try out this theme on the WDTV Live Gen. third I’m very excited about this theme, everything works great except for one small thing that bothers me. The created movie sheet is too big and very pixelated. How do I get back in the correct resolution. I’ve already looked at the video guide, but it does not get out easily.
Would be nice if someone could help me.
Are there any confirmed working themes that use movie sheets with the hub using the latest firmware?
If not, I will do a search on how to revert back to an older firmware version that works with this last updated theme of yours.
Also if I have the WDTV SMP with Black Mamba installed and already have movies sheets generated with thumbgen for Black Mamba theme will I have to use only one theme across all devices in my network or can I use two different themes, one for the SMB and one for the Hub? Would I have to generate two seperate movie sheets for the two themes? Is this even possible?
Thanks in advance for any advice or suggestions on this matter.
I believe you’re asking about the aeonish theme by joey since you posted here, unfortunately this theme isnt compatible with the last fw, (i still hope someday…) for the others i don’t know sorry
About the black manba you should post in the black mamba thread
Is there a mirror of the files anywhere? I’ve downloaded the theme but then hotfile just keeps telling me im already downloading something, waited over 2 hrs. Still the same.
I hope you don’t mind but I have used this menu format on a theme that I am using on the Hub.
Just one question though, what is the font you used for the menu (Games, Online, Photos etc)?
As this menu was created before WD put games on the hub, this menu is no available. Also there is no firmware upgrade menu. I want to change the ONLINE to SERVICES.
Are you able to let me know the font so I can upgrade this to my liking?
