Æonish Hub ReV2 [WDTV LIVE HUB]
Hello friends
i need your help
 in Æonish Hub FR Revision 2 theme for the preview mode i want to use the solid background image instead of backdrop. i tried to edit  rv_preview_browse_page.xml. but it didn’t work. Can anyone tell me which lines i have to change and how to .please help me
http://community.wdc.com/t5/WD-TV-Live-Hub-Themes/%C3%86onish-Hub-FR-Revision-2/td-p/181990/page/45
See Post by w00tifrutti and my reply underneath.
ya but the edited xml file is removed due to copyright claim in hotfile. can you please post the file again
oh :neutral_face:
I will edit the file again and repost later today.
EDIT: Ran out of time today … Tomorrow
thankyou joey. take your time. not in a rush
is there any chance this wud work with WDTV live?
excellent work btw, kudos to you indeed.
Hello joey
i asked thi you before. you said that you will post the edited xml file. but u didn’t. i think you are very busy. whenever you get time can you please do this. thankyou.
…Original…
Hello, harisj16
Sorry for taking so long, my apologies (been busy)
Anyway ive taken the time to remove ALL Backgrounds from Video, Music and Photos.
So you can choose which xmls you wish to use. (unzip and copy and overwrite the originals and cycle the view)
DOWNLOAD LINK:
http://www.mediafire.com/download.php?0d2ffyy4pd803bz
THANKYOU JOEY
YOU ARE GREAT
@harisj16
No problem :smiley:
hello joey
DeVicious wrote in the BlackMambaThread ( http://community.wdc.com/t5/WD-TV-Live-Hub-Themes/BLACK-MAMBA-V1-3-Updated-April-15th-2012/td-p/377799/highlight/false/page/62) (page 62 if the links will not work) that he integrated a “now Playing”-Button with keeping the interactive (?) menu and that it was easy. I ask you several times ago for a “now Playing”-Button in the AEonishID3-Theme. I think, the menu is similar to the BlackMamba-Theme. I would prefer your Theme and ask you: is there any chance for a workaround for the AEonishID3-Theme to integrated an “now Playing”-Button. Or is this to hard work or too much time to spend? Sorry for my bad English.
@mMcCorner
I Disabled the “Now Playing” a long time ago as i felt it was a “Pop-Up” which interrupted the Order of Items in the Main Home Screen.
What others are doing with Home Screen Themes is not New, i simply chose to Disable the Feature. (I also Disable the Firmware Update Notification on the Home Screen as Well)
Anyways, if you really want the “Now Playing” Option … here it is (Re-Instated into AEonishID3-Theme)
http://www.mediafire.com/?vf86f28d1qd4ry2
The “Overlay” for the Now Playing is Located along with the XML files… if you want to design or use your own background.   (HomeScreenNowPlayingOverlay.png)
hello Joey
Thanks for the reply. Now another question:
I love the idea to see the album cover in the CD-box (250x250) and to see the whole  background on your desktop. (I know the differences in AEonish with and without ID3).
The code is as follows:
CD Box:
Desktop: <image image = “@ @ album_cover” x = “0” y = “0” w = “1280” h = “720” scale = “100” scale_type = “pan” align = “left” bg = "1 "/>
Both rely on “@ @ album_cover”.
Are these the embedded covers in the MP3-files or a folder.jpg?
Embedded covers are only permitted up to a size of 500 x 500 pixels. As background on the desktop is not beautiful.
Can I point to the background on a particular image (eg folder.jpg in 1208 x 720) and for the small view (CD box) on the embedded cover?
Perhaps such a question has already been made​​.
@mMcCorner
Folder Images ( folder.jpg) wont display on the Home Screen …
It’s Either the “ID3 Embedded Artwork”  … if this is not found then it displays  the  “File Name Image”
example from the “Music Package Download”
  1. Freak Of Nature.mp3                 ---- has Embedded Artwork Which Will Display 1st Priority
Anastacia - Freak Of Nature.jpg     ---- if No Embedded Artwork is found, this is Picture will Display (needs XML below)
Anastacia - Freak Of Nature.xml    ---- Xml for the *.*jpg Album Cover to Display
folder.jpg                                            ---- Used for Folder View in “Browsing” Filter by “Folders”
Full Screen - “Music Sheet” and “Album Cover” only Possible used Original Aeonish Hub with Manually Created “MusicSheets”
fine. tnx :slight_smile:
so if i understand right, it is better for “High Quality Full Screen Album Cover” to delete the Embedded Artwork (because auf low Quality of max 500x500 Pixel.jpg) and use only a high-resolution-pikture together with xml.
like:
is this right?
Hey
First of i am sorry if this have already been answered but it is a rather long thread
I was looking for themes and stumpled over this
http://community.wdc.com/t5/WD-TV-Live-Hub-Themes/Moviesheet-Theme-List/td-p/214008 but the link dosent work.
Is there a updated link somewhere? I have tried the link from this thread but it dosent seem to be the same layouts, and i am using a smp and the theme from this thread seems to be a little buggy with the smp i am hoping the other one works.
any help would be apriciated.
Now thats out of the way This theme is amazing and im very impressed with the speed ;)
so to you and the other themeres a big Thank you from me it is so sweet you make your themes public
:smileyvery-happy:
Hhm ztrust, which link in the theme-overview (to which theme ) do you mean exactly ?
Your posted link works well, I just clicked on it - no problem with it …
But the link to AEonish theme does not work
(the link DIRECTLY UNDER the screenshots)
Over the screenshots there is just underlined text.
Do you mean ?
http://hotfile.com/dl/123929855/48c1e9b/AEonishHub​.rar.html
The is an information about removing it because of the owner has removed it or because of
a copyright problem …
For the smp there is a special version, remeber to upload the zip-file.
“How-to” with smp is written here in the forum, just take the search function.
Thank you - Thank you - Thank you:
for the AEonishID3_NP with “(Now)PLAYING”-Main-Sreen. It is the best for me.
Thank also for the “HomeScreenNowPlayingOverlay.png”. I change it in “main_music_nowplaying_n.png” and I modify the “rv_home.xml” like the AEonish-Original.
So I have Full-Screen-Album-Cover on Now-Playing-Main-Screen and can also have a quick Change to the Songlist/Playlist. :laughing:
One Question (the last, I promise): if I have had over 10 Songs in the Playlist (maybe 99, and now play Song No. 45), and change from the Now-Playing-Main-Screen to the Songlist:
it is possible, that the Songlist go to the actual playing Song (here No.45). Maybe with a little Icon as NowPlay-Symbol. You understand?
EDIT: sorry, i think, the Songlist jump to the aktuall playing song. But there is no Playing-Icon. But no Problem. i love it.
I love this theme,although it’s not designed for the SMP l’m going to give it a try.
thanks, JoeySmyth :smiley:
