Good work for your mod is the best one for the moment with Firmware 3.01.19 for WDTVLiveHub… I 've begin to make little tweak, but i’m really confuse about some concept. Then i’ve decide to make an analyst of the situation before using thumbgen.
I will using Lstar movie sheet and Lstar TV sheet for displaying my thing. For the moment AEonish was little buggy with 3.01.19 but it’s seem the best solution that I’ve test. (AEonish, DeVicious 1.8, JSMod and mojo). Then i’ve Put all Folder example of each theme and starting analyst.
1)Movie All → 9Slide + Split → Working Structure → From DeVicious/Movies (For thumb and backdrop)
2)Movie All → List+Preview → Working Structure → From JSMOD/Movie JPG & DeVicious/Movies (For thumb + backdrop)
3)Movie All → Description+Split → Working Structure → From Devicious (For thumb + backdrop + text + preview)
4)Movie All → 5 Slide+Preview ->Working Structure ->From Aeonis(Preview) From JSMOD JPG(backdrop) From
JSMOD PNG (reset default background) From Devicious (Thumb)
5)Moviel All->Wall 7x2 → Working Structure → From Devicious & JSMOD JPG
Attempt to rebuild structure
movie.mkv (main movie)
movie.xml (description)
movie.mkv.tgmd (does neccessary)
Result
Conflict display two time movie.jpg (don’t take sheet in consideration for background) (can make split screen)
Conflict display… movie.jpg dont need to be show in background
Conflict displat… movie.jpg dont need to be show in background
Conflict display… backdrop have weird effect
I will try to fix it, but dunno how may time i’m gonna take it… but for the moment, i will ask you if you want shoot me all default background (your skin are totaly clean), because i will made a French pack for your skin… I already download menu in png mode… i work on french subtitle but need backgroud to merge it back… for setting menu (no transparency… then no need to have original)… The package gonna be a rar (structured) with only menu image set.
P.S. Keep going on your project, we appreciate… and sorry for typematch fault… i come from quebec…
other recomendation : 1) accuweather on main menu, in setting/about/text “for additionnal…” need to be lower for french version (like 10-15 pixel) and 3)Oh, with 3.01.19 firmware (trick png to jpg was not supported) but we can continue to cheat it :manlol:
