Aeonish Hub Moviesheets Edition
OK, thankx…
On what xml file can i remove the file name on the bottom of the moviesheet (in red on the screenshot) ?
Thank you…
@Tolrac
rv_gallery_browse_page.xml
Delete the code in RED (the 2nd last line at the bottom)
<?xml version="1.0" encoding="utf-8"?>
<page background="./image/RV-BG_3.jpg">
<!--moviesheets -->
<image image="@@preview_rect_image" x="0" y="0" w="1280" h="720" default_image="@@default_preview_rect_image" textcolor="@@preview_rect_color" keycolor="1" ignore_keycolor="1" bg="1" />
<!--end moviesheets -->
<image image="image/Gallery/video_browse_gallery_overlay.png" x="0" y="0" w="1280" h="720" bg="1" />
<ctrlgrp>
<include filename="./rv_multi_edit_ctrls.xml" />
<include filename="./rv_browse_common_ctrls.xml" />
<linebreak />
<listbox valkey="browselist" move="row" cols="8" rows="1" lbmask="ud" loop_scroll="1" turbo_trigger="10" turbo_multi="10" autoenter="1" fixed_scrolling_col="3" hormove="1" />
</ctrlgrp>
<!--mirror thumbnail -->
<wrapper y="659" w="134" h="201" align="hcenter" scale_type="" scale="100" mirror="1" selected_scale="100">
<image image="@@browse_0_thumbnail" x="86" disable="@@thumbnail_disable_0" default_image="@@default_thumbnail_0" active="@@act-browselist-0" name="th0" />
<image image="@@browse_1_thumbnail" x="225" disable="@@thumbnail_disable_1" default_image="@@default_thumbnail_1" active="@@act-browselist-1" name="th1" />
<image image="@@browse_2_thumbnail" x="364" disable="@@thumbnail_disable_2" default_image="@@default_thumbnail_2" active="@@act-browselist-2" name="th2" />
<image image="@@browse_3_thumbnail" x="503" disable="@@thumbnail_disable_3" default_image="@@default_thumbnail_3" active="@@act-browselist-3" name="th3" />
<image image="@@browse_4_thumbnail" x="642" disable="@@thumbnail_disable_4" default_image="@@default_thumbnail_4" active="@@act-browselist-4" name="th4" />
<image image="@@browse_5_thumbnail" x="781" disable="@@thumbnail_disable_5" default_image="@@default_thumbnail_5" active="@@act-browselist-5" name="th5" />
<image image="@@browse_6_thumbnail" x="920" disable="@@thumbnail_disable_6" default_image="@@default_thumbnail_6" active="@@act-browselist-6" name="th6" />
<image image="@@browse_7_thumbnail" x="1059" disable="@@thumbnail_disable_7" default_image="@@default_thumbnail_7" active="@@act-browselist-7" name="th7" />
</wrapper>
<!--thumbnail -->
<wrapper y="458" w="134" h="201" align="hcenter" scale_type="" scale="100" selected_scale="100">
</wrapper>
<!--thumbnail_f -->
<image image="@@browse_0_thumbnail" x="86" disable="@@thumbnail_f_disable_0" default_image="@@default_thumbnail_0" active="@@act-browselist-0" name="th0_f" />
<image image="@@browse_1_thumbnail" x="225" disable="@@thumbnail_f_disable_1" default_image="@@default_thumbnail_1" active="@@act-browselist-1" name="th1_f" />
<image image="@@browse_2_thumbnail" x="364" disable="@@thumbnail_f_disable_2" default_image="@@default_thumbnail_2" active="@@act-browselist-2" name="th2_f" />
<image image="@@browse_3_thumbnail" x="503" disable="@@thumbnail_f_disable_3" default_image="@@default_thumbnail_3" active="@@act-browselist-3" name="th3_f" />
<image image="@@browse_4_thumbnail" x="642" disable="@@thumbnail_f_disable_4" default_image="@@default_thumbnail_4" active="@@act-browselist-4" name="th4_f" />
<image image="@@browse_5_thumbnail" x="781" disable="@@thumbnail_f_disable_5" default_image="@@default_thumbnail_5" active="@@act-browselist-5" name="th5_f" />
<image image="@@browse_6_thumbnail" x="920" disable="@@thumbnail_f_disable_6" default_image="@@default_thumbnail_6" active="@@act-browselist-6" name="th6_f" />
<image image="@@browse_7_thumbnail" x="1059" disable="@@thumbnail_f_disable_7" default_image="@@default_thumbnail_7" active="@@act-browselist-7" name="th7_f" />
</wrapper>
<!--Mirror thumbnail_f -->
</wrapper>
<!--selection -->
<wrapper y="438" w="181" h="232" align="hcenter" scale_type="" scale="100" selected_scale="100">
<image image="@@frame_0" x="63" />
<image image="@@frame_1" x="202" />
<image image="@@frame_2" x="341" />
<image image="@@frame_3" x="480" />
<image image="@@frame_4" x="619" />
<image image="@@frame_5" x="758" />
<image image="@@frame_6" x="897" />
<image image="@@frame_7" x="1036" />
</wrapper>
<image image="image/Bottom_Mirror.png" x="0" y="613" w="1280" h="110" align="hcenter" scale_type="" scale="100" selected_scale="100" />
<text text="@@browse_text" x="138" y="676" w="1000" h="18" fontsize="18" textcolor="0xbbbbbb" align="hcenter" speed="2" delay="1" />
</page>
Ok, thank you JoeySmith for this tips… :smiley:
Can anyone help please?
I have just changed to the Aeonish hub Moviesheets edition and changed (FW to 3.06.14) The download was  (AeHubMovEdit.rev3).
I cannot get any thumbs, sheets etc to show up. I was able to do this in the original Aeonish theme. i know you had to set thunbgen to a png setting in output file and the template was a cover and fanart combination.
I have successfully loaded the templates for AeHubMovEdit.rev3 which are fine but when i save the files and transfer to the Wdlivehub they just don’t show.
Any idea’s. do i need to change the thumgen settings to something else?
i know in the original Aeonish theme i would use e.g
                                                       Looper .xml
                                                       Looper. mkv
Any help would be much appreciated.
NEWS FLASH  this just in …
*.png to *.jpg trick does not work anymore on the WDTV Live Hub as of Firmware 2.08.13
6 October 2011
http://community.wdc.com/t5/WD-TV-Live-Hub-Issue-Reporting/PNG-s-do-not-display-correctly-for-files-folder-thumbnails/idi-p/268062
Download Link to Firmware 2.07.17 if you want to Rollback.
http://download.wdc.com/wdtv/Rollback_wdtvlivehub_2.07.17.zip
Thanks for the info.
What if i decided to stay with the current version of Aeonish Hub Moviesheets.
how do i create the thumbs, sheets, etc now.
Is there a tutorial link?.
PLease advise.
Nig
@WDNig
I currently pretty busy with other stuff … so hopefully Medic can provide a full Tutorial for you.
te 1st 2 lines in the feature section of the theme in the first post should answer this:
Thnx guys for the replies, and as allways you are both right … :stuck_out_tongue:
No png’s for the sheets and covers …
Never did a full Tutorial, on page 4 theres a screenshot walkthrough how to set up ThumbGen for this.
  1. If everything on the Hub works for you at this time then theres no need to change the Firmware. That is if you want to make new sheets and covers.
  2. Just change the file output settings (for covers and sheets) in ThumbGen from png to jpg thats all you have to do.
Updated page 1.
It’s easier to have the complete theme, updates and all templates in one Download.
Hello. All:        REF: (Aeonish moviesheets v3)
Many Thanks for the responses and being directed to page 4 of this post for details of thumbgen option selction.
I have managed to now get to gripps with creating jpgs, sheets, xmls etc which are all running fine. My only question is when you slide from movie to movie, the movie backdrop sheet takes about 3 seconds to fade in.
Is there a way or option to make this instant without the pause before the sheet shows up.
I know when i was running the original aeonish png edition, it was very instantaneous. I can appreciate that the programming was different, but this new edition (moviesheet edition v3.) is now my preffered.
Please let me know if there is anything i can do to speed the sheet display time.
Many thanks Wdnig
WDNig wrote: … My only question is when you slide from movie to movie, the movie backdrop sheet takes about 3 seconds to fade in… Is there a way or option to make this instant without the pause before the sheet shows up.
No this is firmware related and for this sort of theme the fasted way possible.
@WDNig
“Is there a way or option to make this instant without the pause before the sheet shows up”
" Linksheets"
http://community.wdc.com/t5/WD-TV-Live-Streaming-Discussions/THEMING-ISSUE-FOLDER-THUMBNAILS/m-p/535195#M17305
Looks great, has anyone modded it to work with the SMP?
Nvm, still new to this. Figured it out, Thanks.
Hi, (this is for Medic)
This is my first post, i have been reading this thread and came across your help here.
My problem is that I cannot find the actual .tgb profile “WD TV live hub tv sheets” like you have in the drop down menu, all the others I have like in your example.
I just got my player, so am trying to work it out!
I’m a working mum of 3, so I don’t have too much time to read through loads of posts, so any help would be really appreciated!
Thanks and have a nice day! :slight_smile:
Sorry I didn’t post correctly this is directed at Medic and your screenshots! Thank you
sorry, I posted twice and not sure how to delete! :stuck_out_tongue:
No problem …
About the WDTV Live TV Show Sheet in the dropdown, it comes with ThumbGen so it’s nothing fancy and can be found in this screen …
Click the dropdown menu at the top left of the ThumbGen Home screen.
Medic wrote:
No problem …
Hi, thank you for answering!
Hmmm, i don’t have that in the drop down menu…my version of ThumbGen is 1.3.2.0 is that the reason?
Thank you, I’m trying to wrap my head around how to get it to work on the WDTV Live HUb…everything seems to be missing or mixed up! (All my mistakes of course!)
Thanks Medic! :slight_smile:
EDIT: I’m downloading the new one…kind of a noob thing to do! lol
One question, whar file do I place on the wdtv folder in the actual player…thank you!
OK I downloaded  1.3.5.2 and still it does not have the WDTV Live hub in the drop down menu! Any ideas? Thanks
Thinking about it i can’t remember but it is possible i created these two HUB items myself … :wink:
Make all the settings ( Options ) needed for Moviesheets. Then click the green + button to save these settings as a profile like the one you are looking for. Then repeat this for TV Shows and save this profile.
Now you have both Movies and TV Shows for your Hub in the dropdown box
Question 2
Not sure what you’re asking but try this:
On the root of the internal drive make a folder named Movies
Place here your movie file. movie thumb, movie backdrop and xml
Then it’s up to you if you want to use the build-in Media Library or not. If you want to use it. Go to options/system turn on the media library and let it build. When ready go to Video in the Main Menu and choose your wdtvlivehub/movies folder
If you don’t want to use the media library choose Video in the main Menu. If promted for a Source choose the internal drive and look for your wdtvlivehub/movies folder.
Then if you did it all correct your movie inclinding thumb and backdrop should be there.
If the backdrop rotates to quick go to the photo settings and select an higher rotate interval eg 5 minutes …
