I ended up on the latest version FW while trying to fix a network problem. Usually I would have stayed at 2.07.17, but not seeing the network for days convinced me to try anything to get it running again. Long story short … Now that I am at 3.03.13 I have 2 new problems. The audio drops out for a few seconds while in netflix and I can’t downgrade to 2.07.17 (did they “fix” this FW so you can’t downgrade it?
Thanks,
Mike
Solved the “can’t downgrade” problem. I forgot to change a couple of options so it can see the USB stick FW. I will update this post to tell you if the netflix audio drop out is fixed by this downgrade back to 2.07.17.
Enjoy,
Mike
After downgrading to 2.07.17 the audio thru HDMI dropout problem is fixed. Just another problem with the latest FW. I think I will stay at 2.07.17 forever or until they actually fix a FW instead of making things worse.
Enjoy,
Mike
