Recently I tried to install the latest version of minidlna. I had to install the prerequisite software first. The system suggested doing a “apt-get install -f”. Without reading carefully what it really meant, I executed that command and now apt-get doesn’t even run.
MyBookLive:~# apt-get
apt-get: /usr/lib/libz.so.1: version `ZLIB_1.2.3.3’ not found (required by /usr/lib/powerpc-linux-gnu/libapt-pkg.so.4.12)
MyBookLive:~# ll /usr/lib/libz.so.1
lrwxrwxrwx 1 root root 15 Sep 18 07:00 /usr/lib/libz.so.1 -> libz.so.1.2.3.3
MyBookLive:~# ll /usr/lib/libz.so.1.2.3.3
-rw-r–r-- 1 root root 86440 Apr 7 2008 /usr/lib/libz.so.1.2.3.3
MyBookLive:~# ldconfig -v | grep -i libz
ldconfig: Can’t stat /lib64: No such file or directory
ldconfig: Can’t stat /usr/lib64: No such file or directory
MyBookLive:~# ldd /usr/lib/libz.so.1.2.3.3
linux-vdso32.so.1 => (0x00100000)
libc.so.6 => /lib/libc.so.6 (0x6fe20000)
/lib/ld.so.1 (0x207a0000)
How can I fix this problem? Thanks for any suggestions.
