I’ve borrowed a USB Wireless Stick from work to try it on the TV Live,
the Live doesn’t see it ?
BUT, when you use it on a PC it SEE’s it but then needs to install
the drivers to use it . . . . . .
The only thing is, if I follow the Owners Manual for the Live, there
is no choice of WIRED/WIRELESS in the Network Setup screens.
Is this because the USB is inferior or is it that MY Live can’t/won’t
use a wireless setup ?!?!?!?
[don’t want to spend £25 plus for a better Stick if it’s not gonna
be any use ???]
Thanks,
FiveB’
