I don’t know if this is your problem, but some wireless routers have a setting for wireless isolation (my Netgear 3700 has it). Wireless isolation prevents the wireless clients from accessing the other wireless and wired clients (can only access the internet). If you have that option, make sure that it is turned off.
This not my problem, no such options and I can access the laptop shares with other wired device on the network, problem is isolated to the WD TV Live.
Thanks for the link, didnt change much, not sure problems comes from Windows since that once I plug the same laptop with a network cable the shares work, its just once I go wireless that laptop no longuer showing
