Wireless Pro flashing blue lights
All six blue lights on MyPassport wireless pro begin flashing while trying to connect wirelessly. Cannot connect with the USB to my new MacBook pro with the M1 Chip. Have not found any solutions for the connection problem nor information on the blue flashing light but I am unable to connect to my passport either way. Anybody have a solution to this problem, or know what the flashing blue lights means?
Hi @CapJohn,
If it is in warranty ask for a replacement if you don’t mind to lose the data because they don’t recovery data.
But If you don’t want to lose data … open the HDD and connect it without the box through an adapter. Then copy all your data in other one. Hopefully I had know this because my HDD is broken and all data lost.
