Thank you! I can finally use my 5.0Ghz band for my media meaning no more choppiness when the guys are transferring files over the wirelessl network!
I wonder what other things have been invisibly ‘fixed’ that aren’t in the notes
ive been using the 5ghz band with the orig .00 firmware
Hey SeaUrchin, what firmware has you installed before and wich one are you using now ?
I´ve a Wireless N Linksys router and a Buffalo miniUSB N adapter in my WDTV Live but I’m not sure that it has the best performance…
Same hare had no problems with 5ghz before the update…
I also have the Buffalo miniUSB N, and Wireless N Linksys router. Can’t even see the SSID for the wireless N =/.
