First let me say thank you for any help before I ask my question. I have a WD TV Live HD Media PLayer , I bought a D-Links DWA-131 Wireless N Nano USB adaptor. When I strive to install it on my Media Player it will not recognize wired or wireless as the instructions indicate. I can get it to work on my laptop. Could it be the box itself and it’s USB connector, but I did try both of them and got the same results As far as I can tell it is on the acceptable USB wireless list. All I want to do is to be able to stream the content from my harddrives. Thank you again
i have dwa-131 usb adapter also. i can see both wired and wireless network but after i input the SSID, it says “Unable to obtain the ip address. The media player has limited or no network connectivity”. i even upgraded the firmware to 1.03.39_B and still no help. only problem that i may see is that the manufacturer had changed the chipset after WD tested. i should’ve done some research before i purchased this adapter last week. it’s too late for me to returned since the box is trashed now. it seems like only way to solve this is to get 100’ ethernet cable… lolz
After you put in the SSID, it should ask you for the security key or password. It’s not doing that? Are you running your wireless WITHOUT security? (If so, Shame Shame!)
