I have a 802.11n Wireless LAN Card in my PC (Win7). Can i connect the SMP (F/W: 1.15.10) to my PC, without a router?
Hi, to access the WDTV you need to use a router/switch or use an Ethernet cable for a wired connection.
Ok thanks. Got it working 100% wireless. Now I’m thinking it would improve speed/stability if I plugged it into the PC or the WDTV with the network cable, and let it interact wirelessly with the other one. If so, would it be better off plugged into one or the other?
