Wireless adapter not detected
I’ve just bought an Belkin Wirless Micro Adapter N150 to my WD Live TV HUb but it doesn’t seems to be detected.
The device:
http://www.amazon.fr/gp/product/B001BROKXO/ref=s9_qpp_gw_ir01?pf_rd_m=A1X6FK5RDHNB96&pf_rd_s=center-7&pf_rd_r=086WYSRPNV0JA4V2MEDB&pf_rd_t=101&pf_rd_p=463772333&pf_rd_i=405320
Any idea ?
Neither the N150 or whatever that is you linked to are supported.
http://wdc.custhelp.com/app/answers/detail/a_id/5688/
Thanks for your answer.
I made a search on Amazon FR for “F5D8053” and i found F5D8053ED, is it ok or do i need to find the exact reference ?
